What cameras are you guys using? GoPro, Sena, other? Help!
Mike,
Great question. Camera selection is dependent upon application. If I read right, you want something that is "permanently" affixed to the bike and recording at all times when you ride. This eliminates the GoPro right off the bat, and indicates you want a dash cam solution. The difference is, when power is applied to dash cam, it is recording always, fills up the SD card and then writes over the old files. In this manner if you have an incident, the camera will have already recorded the previous 2-3 hours or so of video for you to peruse on your computer by removing the SD cards. You can select the size of the video files. For example 5 min each or 10 min each.
Go to Amazon, search for Dash Cam and sort by prices from low to high. Get yourself a $25 dash cam and try it out. If you're happy with it, get a couple more, to have front/rear and a backup in case of damage or loss. Good luck! And keep us updated.
You can set a GoPro to record on a continuous loop.
I have a Hero 5, with a 64G card and it records 5 or so hours of 4K video.
My 2018 Softail also has a USB charging port. So I should be able to bar mount the camera and have it charge from the USB as I ride. Haven't tried that yet as it's still winter - but I will definitely try it when it warms up.
Battery life on the GoPro sucks when recording 4K. I'd only get around 1 hour from a battery....
And thanks to my go pro mount breaking, my camera just flew off my front fender and across three lanes of traffic to get run over.
I went back to get it and it still works so that’s pretty cool. Somehow it stopped recording before it happened so no footage.
It’s scraped up but held up pretty great but thinking I might add a tether to the rear of the camera just in case that happens again.
For the front camera, I used the little angle brackets that come with it, along with a hose clamp, to secure it on my Heritage to a bar that runs across the front.
The rear camera, also with a provided bracket, I used one of the license plate reflector screws to mount it just beside the plate.
As to the controller unit...ah, that's a pickle. I have bags, and as of now I can't really take them off if I wanted because the controller, speaker and the wire jumble are in there. Along with the controller for my LED lights, too, unfortunately. When the weather is nice enough (or sooner, if I shove my poker tables out of the way and bring the bike in the house), I want to try to figure out some way to relocate everything. I had bought a waterproof box from Amazon, with the intention of putting it on the rear fender, behind the license plate, but turns out that while the box would fit great there, it won't hold all the wires and units. I could get a bigger box, but I'm thinking that my best bet is likely to get as much of the wire under the seats and get just the controller units in the box. I have rubber grommets and the tools to proceed, but not really going to cut it alone without wire bundle relocation.
When (or if) I get to it, I'll document the whole thing and put it on my blog. Likely won't be in time to help you out. Soonest I'd likely get to it would be the last week of March when the wife is out of town for a trip to Morrocco. Maybe sooner, can't promise. On the header picture on this blog page of mine (https://twowheelsonebike.wordpress.c...ing-your-bike/) you can see the wires to the front and back camera, though the angle isn't really good enough to see the cameras themselves. I'm sure I have more pictures, but need to be at the house to go through them.
INNOVV K-1 on a Heritage
However, regarding the DVD module it seems it comes with a mounting bracket that it clips into (correct me if I'm wrong) that is intended to be mounted in a protected place.
I like the idea of a weatherproof box, but would like to find a place up in front where it would be easily avvailable but out of sight. I don't want to locate in the saddlebags for just the reasons you mentioned.
My bike has a USB port on the left side just below the Gas tank on the frame. With a USB spliter I can easily power both this system and my Phone.
I'm thinking possibly of using velcro to mount the DVD bracket, or a weatherproof box/bag, to the inside of my Windshield tucked down near the cutout area for the headlight. Hopefully all excess wiring can then be hidden under the tank and/or under the seat.
I expect the system to arive soon, but since I don't have it yet, can you tell me if there is enough wire lengths supplied to locate the DVD module up front.
BTW....It will warm up!!!!
Thanks again,
Good luck with it. If I get some better pics, I'll let you know with a reply to this post.
FrankEV (02-12-2018)
INNOVV K-1 install on my Cherry
I just posted a lengthly write up with pictures of my install on another thread. Please go to https://www.hdforums.com/forum/off-t...sh-cams-3.html if you want to read it.
