'18 Heritage Fork Wind Deflectors ???
The deflectors do reduce the updraft from below the windshield. The taller the shield the worse the air buffet trying to fill in behind.
I guess when I install them I'll fasten the top bolt loose then swing or tap the deflector against the bottom fastener head to mark the location. Make it large enough for later fore and aft adjustment if I install engine bars.
Read about your vibes. Might look for obvious engine and exhaust contact with the frame or boards. Also try loosening, running the engine briefly, and retightening the exhaust system's fasteners. Sometimes the exhaust binds or whatever and needs to be reset. Same for engine mounts. The dealer should have a look and see what they come up with.
Gary
Gary
DeeRides
05-30-2018 11:54 PM
zuma
11-23-2008 11:00 PM
