2006 FXSTSFI change from 200 Rear tire
I have a 2006 H-D Softail Standard (EFI) with the 200 Rear tire and solid rim (factory I think).
I want to switch to a narrower rim / tire. What all is needed? I have the skinny belt. Is there a specific spacer kit to use with the narrower rim? Factory or aftermarket available? Recommendations please.
A few people with spoke rims have kept everything stock. Stock hub, stock brake, even stock spokes just laced to a rim that is not as wide. Having a solid rim that you do, I'm afraid this post will not help you sorry. Just thought I would throw it out there. If you did go spoke, a stock xbones hub is easily laced down.
