Need a new battery questions...
Probably goin with a Deka, but considering lithium. Are there any major advantages gained by using lithium? Opinions please. Also was wondering since this is the first time I’ll be disconecting it... Will it delete my saved map that I have installed from fuel moto? Thanks gang |
Map should be retained. Would tell you about the battery but it'll just start a fight with another forum member here who apparently has sexual relations with his Deca batteries.
The first thing I know about Lithium batteries is they are lighter. the other thing I forgot, which happens alot now.
lighter,more cranking amps,and last alot longer..have one now that is 10 years old and still cranking well
When HD battery failed on last bike I went with lithium. It was much stronger, much less dependent on tender, much lighter. Only down side was initial cost - otherwise totally positive.
Originally Posted by Da-Rza 21
(Post 17094080)
(Post 17094080)
Originally Posted by rednred
(Post 17094411)
good ole cheap dumb battery chargers will charge lithium's properly. Do not get the fancy ones with the desulfation mode or weird do dads. The original battery tender or the Duraboost Battery Maintainer 1000 works. I have the duraboost hooked up to my KTM but as soon as i plug it in, the battery states it's fully charged. That's how awesome these new Lithiums are.
The only quirks that lithiums have is that in the winter when its cold, you have to warm up the battery like you are starting it, wait a few secs and then hit the start again. |
Originally Posted by vizcarmb
(Post 17094657)
Originally Posted by Rocker B
(Post 17094719)
That's good to know, I thought (when needed) the lithium's required a specific kind of fairly expensive, charger/tender.
Great info. And glad to hear my maps dont need to be re dowloaded thanks |
© 2024 MH Sub I, LLC dba Internet Brands
