Rider boards on a Deuce?
Anyone know if it can be done with stock parts. If it can, what parts I would need to put rider floorboards on my Deuce? And whether or not I would have fitment issues with the exhaust that's on it now? Or with stock exhaust?
https://cimg3.ibsrv.net/gimg/www.hdf...57d5e238cd.jpg |
With those V&H pipes the standard Harley softail mounts and passenger floorboards should work.
I just went through trying to figure out which passenger floorboards to put on my Fatboy. It seems once you get rid of the factory exhaust, options open up that Harley says should not fit. If you've got a dealership near you, they should let you take the brackets outside to see if they will fit. |
Something to ask next time I'm up that way. It's about 75 miles away. Good excuse for a day in the saddle though, thanks.
I think it is the same frame as other Softails, a Cross Bones full system went bolt on on my FXST with stock pipes, you have to remove the front pipe to install though
Thanks klf33. I'd most likely have to pull the V&H pipes off too I would think. If they would even work with the floorboards at all. Not a lot of info on these pipes out there. Will likely need to take the time to go up to the nearest harley shop, as fatdaddy suggested to see they can help me verify fitment.
doesn't look like the exhaust will clear...you could try some mini footboards for more support without having the buy all the stuff...mounting bracket, brake pedal. there are several diff styles of mini boards an I thought they really helped on my V rod. here's the ones I had on it:
an there's this style I have but never installed:
https://cimg4.ibsrv.net/gimg/www.hdf...c4c264d2a0.jpg |
That board in your last picture is the one that has me the most curious. Are they supposed to mount with that single "peg" mount that is shown? I assume that one is the left board? Thanks for the pics and the ideas langwilliams.
DK Customs has a nice set...check them and see if they will work.
© 2024 MH Sub I, LLC dba Internet Brands
