Softail Tranny Sticking
Old Jun 25, 2007 | 09:45 PM
jumpmasterjay's Avatar
jumpmasterjay
Default Softail Tranny Sticking
Anyone else have this problem:
My wife's 06 FLSTN Softail Deluxe transmission sticks in certain gears (1-2-3). Also, the shifter linkage does not return to a "neutral" position after shifting (it stays up or down and not to the "ready" position).
Anyone have any ideas before I take it to the dealer and get the usual "all Softails do that."
Thanks,
Old Jun 25, 2007 | 09:49 PM
thelawdoc's Avatar
thelawdoc
Default RE: Softail Tranny Sticking
Hey, I had that exact same issue. My '06 Deluxe was on the road less than 6 months, with less than 3k miles. Dealer said he repacked the bearings in the shifter. Seems to me that it is easy enough to do on your own, especially if you have the manual. Since then, I have had no more problems with it. Dealer said not to wash it too strongly with the hose on that spot.
Old Jun 25, 2007 | 10:04 PM
DaveJ's Avatar
DaveJ
I bought an aftermarket shift linkage. I know they are expensive, but they have ball joints so they don't get stuck and look a hell of alot better, IMO.
[align=left] [/align]
Old Jun 25, 2007 | 10:10 PM
thelawdoc's Avatar
thelawdoc
Well, it seems that it most likely is going to be some kind of lube issue. I am no mechanic, but doesn't a ball joint also make use of grease? I feel sure that what you describe simply entails taking it off, cleaning/lubing and putting it back on. Then, if that does not work, I guess it is off to a mechanic. But all in all, there can't be much happening or complicated around that ball joint. Maybe just some grit got to it. Ok, good luck.
Old Jun 25, 2007 | 10:20 PM
DaveJ's Avatar
DaveJ
ORIGINAL: thelawdoc
Of course they all need lubricant, and I am sure the stock linkage can be fixed. But the stock one is pooly designed; I have read a hundred threads here with this same problem. I am not suggesting that replacement is the only answer, but if you want to get rid of that hideous looking piece of scrap metal HD calls linkage and fix the problem, it is a good solution. IMO.
Old Jun 26, 2007 | 07:12 AM
TraumaKing's Avatar
TraumaKing
It's a simple easy fix! I had the same issue with my Springer about 2 weeks after I bought it.
Remove the toe and heel shifter levers then remove the front assembly by sliding it out from the rear FRONT bushing bracket( very easy to do) you will see a bushing with a sleeve, remove the sleeve and get a drywall sand block ( fine grit) and buff the crud on the bushing.........your done! takes all of about 15 minutes. Never had another problem. The service Tech at Lancaster HD in Pa. told me over the phone instead of running all the way in there for something so simple and he was right!
As you see in the area highlighted by the white box the black stationary sleeve that the shifting linkage articulates inside of , this is what you need to remove the inside of, where you will find the bushing and need to clean/buff, reinsert and replace the heel toe shifter and your ready to roll!
Old Jun 26, 2007 | 01:19 PM
CNC WHEEL GUY's Avatar
CNC WHEEL GUY
ORIGINAL: TraumaKing
I agree with this too. Had the same problem, only I took apart the assembly and put some light grease in the sleeve and on the shaft when I assembled it. Works ****-ah!
Old Jul 4, 2007 | 11:25 PM
jumpmasterjay
Thanks all,
I looked at my road king and decided that the hell-toe shifters were on too close to the housing. I back them off (made them flush with the end of the stud) and she shifts like a dream (better than before) and there seems to be no sticking.
If she sticks again, I'll buff down the sleeve and clean the bushings.
Jason
Old Jul 5, 2007 | 05:20 AM
bobros's Avatar
bobros
Had the same problem. Mentioned it to my dealer, they fixed it immediately. Cover under warrenty.
Old Jul 5, 2007 | 07:21 AM
OneBlackFly's Avatar
OneBlackFly
The aftermarket linkages have sealed ball-joint ends. Look for ones under landmarkmfg.com - they have a good selection and you can purchase directly from them w/o shipping.
