Fatboy Stator died
Yesterday morning I took the bike for a longer ride and on the way home the battery indicator came on. I immediately suspected a failed stator, so I made a beeline for home - fortunately I was only about 30 miles from home when the light came on. I pulled into the garage, left the bike running and verified that the system wasn't charging. Using the diagnostics guide, I was able to determine a short to ground as well as shorts between the three phases of the stator. This morning I placed an order for the Cycle Electric setup and I hope to have it within the next couple of days.
It seems as though the HD systems are prone to failure and I've experienced my fair share of issues, but this is the first time with the TC. At this point I've removed the floorboard, shifter and primary cover. So I have a few questions...
- What can I use to lock the primary / clutch in order to remove the pulley on the TC? The tools I've seen appear to be nothing more than a flat piece of stock that is fitted between the teeth - I used a brass door hinge on the Sporty.
- Once the primary chain tensioner is removed, can I get away with removing only the engine sprocket or will I have to remove the clutch basket as well?
- And finally are there any other items I should look at while I have the primary apart? I know certain model years had issues with the tensioner shoes, does this apply to a 2012 TC? Thank you for any input and suggestions.
Shorted to the chassis
https://www.youtube.com/watch?v=GXI5wZ4_PFU
Finally got the rotor to come off, Now i wonder how many of the stator screws are going to either strip or break. It was definitely burned and the rotor looks good.
Before grinding
Finally got it off
Cycle Electric part installed
Surprisingly, none of the screws gave me a hard time and I put in the cycle electric stator, cleaned up the rotor and reassembled the primary this afternoon. Tomorrow the voltage regulator is scheduled for delivery so I should be up and running by evening. I was surprised that the HD service manual did not mention the interference problem with the inner primary.
