Speedometer Fogging repair?
Has anyone sent in their Stock Harley Speedometer to a shop and had the fogging glass staining issue repaired with goods results? My 2018 Slim has the same issue everyone else is having and ultimately the drying wetting ruins and stains the glass. My dealer is aware of the older SB that Harley has been working on a fix for many years and to date, no resolution. I'd just replace the gauge with an aftermarket like I had done on my 10 Streetglide but nobody seems to be making one for the Slim that's plug and play with all of the same factory functions such as gas gauge etc built in.
Thanks for any insight...
I think the answers you're looking for, and probably don't want to hear are in this thread
If you're washing your bike, don't unless there is no other way to clean it. I rarely use water on my bike and it looks as good today as the day I took delivery. If you ride in the rain or have to park outside it's probably something you're going to have to live with.
That said, I hoped someone here with the problem had tried a shop for repair and could make a recommendation based on a success story?
When I take mine in for the 1K service I plan on telling them I don't want it washed when they're done.
On other bikes that I also refrained from washing I have had condensation, usually on cold mornings that then turn hot. It's not double-pane glass so it stands to reason that certain environmental conditions can result in condensation. But if the bike is washed and some water seeps in it will almost certainly take longer for that to be burned off and dried out than simple condensation.
For those that may be thinking of getting it sealed, be careful. If not done right, you'll create a trapped atmosphere in it and if it's not bone dry, you'll make the problem worse..
I had a 2008 Nightster that had the same problem. I removed the speedo and carefully removed the speedo glass bezel and glass. Took a razor blade and remove the coating from the inside of the glass. I Carefully put speedo back together and never had that issue again. The only draw back is the black coating on the stainless steel bezel that holds the glass on peeled off.
Rickr01 (07-18-2018)
