18s stiffer ride then older Softails ??
I have a 18 Softail Lowrider and compared to my old 2012 Softail FatBoy the lowrider has a better more connected ride. Not stiff at all, just nice and firm.
I am 175 lbs and I have the shock preset at the number 1 position, which is for riders between 160 to 180 lbs. BTW I need to mention that the handling as compared to the 2012 FatBoy is much better. The Lowrider just runs though turns like it is on rails.
I would assume the LowRider has the shorter shocks like the Sport Glide. Sounds promising. I admit from a handling standpoint the 18 I drove did handle great. I hope the word, stiff and soft on bumps can be in one bike. As soon as a 19 comes in I will test ride a Softail with the shorter shocks and make them set it to soft if it don't have a **** on the side.
Received 3,389 Likes
2018 Softail Models have easy pre-load adjustability with new rear coil over mono shock. Like others have said this is best riding Harley I've ever owned. Both front and rear suspension has longer shock travel and excellent Showa quality.
Cheers
Cheers
I ride an 18 softail sport glide, I way 157lbs and have the rear on setting 1. It reacts pretty bumpy/stiff to sharp bumps. If i'm on a cement highway, it can feel like I'm bouncing a little as well, hard to explain. It's not like a touring bike give that's for sure, much more akin to a sportster and dyna suspension. I like it it feels more on rails than any of my prior 7 harleys.
After experiencing the improved suspension and handling on my new Fat Bob, I'll never be willing to accept anything from Harley that is less. On my previous Harleys I always bought aftermarket suspension stuff but stock my Fat Bob is nearly perfect. If I had to complain I would say it needs a bit more rebound dampening and the fork dive during braking is a bit much. That said, my Fat Bob is literally an order of magnitude better than any Harley I have had in the past.
