Lean Running Bike
Too rich can cause it too. Unburned fuel igniting inside the exhaust. Or, as others have mentioned, en exhaust leak can definitely cause it.
My bike was doing the same thing a few months ago. I changed intake seals, changed and reseated exhaust several times. No luck. Bike was popping at first and got progressively worse - coughing, sputtering and stalling sometimes when hot and coming to stop. I went thru bike, checked all wiring, replaced several things. Again, no luck until I got a bad intake air temp sensor code l, replaced it, and all problems went away. Bike has run great since then. Are you getting any codes?
Pitbull_Dallas (09-12-2018)
Do you mean air intake sensor or head temp sensor? I replaced the head temp sensor and there was no change.
