What do I need for tire change
Hi All -
I am hoping the good people of this forum can help me out. It's time for a tire change and I'm a noob at this. I am riding a 2018 softail slim with 16" spoke wheels and I have a few questions:
Thanks everyone for your help!
- Tires: I have the tire I want picked out Metzeler ME888 Marathon Ultra Tires. According to my manual the the stock tires are 16" Dunlop D401 130/90B16 BW for the front. The one ones on Cyclegrear are 130/90B16 73H TL Reinforced. Is there a difference between "BW" at the end for the stock tire and "TL" at the end for the Metzeler?
- Similarly, the stock back tire is 16" Dunlop D401 150/80B16 BW. The Metzeler is 150/80B16 77H TL WWW. Do I need to worry about "BW" and "77H TL WWW" difference?
- How do I choose the correct inner tube? I'm on softail slim and when looking at inner tubes on Cyclegear I get two dropdown options
a) Type - the dropdown has values like "JS-87C, TR-6, TR-6 (Centered), TR-6 (Off Set), etc. and
b) Tire Size - how do I which tire size to choose. The dropdown values range from 20x7x8, 3.50-4.00x8, .... 3.25-3.50x21)
4) Lastly, beside tire, inner tube and rim strap do I need anything else? For example do I need a new valve stem or something else?b) Tire Size - how do I which tire size to choose. The dropdown values range from 20x7x8, 3.50-4.00x8, .... 3.25-3.50x21)
Tubes- just ruff size is gooder enough.
Next, If you have not ever done a bicycle tire I am pretty sure this will kick your ****.
Personally, I think you picked the wrong tire.
I have had two ME 888 come apart and if you check the net I ain't the only one.
You need two tire irons , soapy water, a vice or away to bust the bead off.
The best thing you can have is an extra set of hands when reinstalling the wheel. Getting everything lined up and the axle back through is a pita to do by yourself. Especially with that arm for the brake caliper. Don't loose the rubber bumpers for that arm. Unless they stopped using them on the M8 models.
Received 4,369 Likes
Double Trouble
11-22-2012 06:36 PM
