BIG Vet needs more leg room ,forward contrls
Looks like those are further back than stock forward controls. How tall are you? Go to Hognutz and look at the forward controls. I just put a chrome set on our 1995 softail custom . They are a little lower and out than stock. You can get 2 inch or 3 inch extended in the same style there too. Look at there web site and look at this part number . #mu45885. They are a work of art. You will need to remove your stock master cylinder and reservoir and get a 35degree brake fitting and correct thread banjo bolt, and a brake line from the new master cylinder to your existing rear brake switch.
That setup looks stock position for softail, i think it's an optical illusion based on the angle of the pic that it looks non-stock. The Arlen Ness 3" extensions kit comes w brake line and shift rod. cheapest mod out there and relatively easy to install - remove foot control bracket, install plate extension, replace bracket and button up the extras. your seat and handlebars will go a long way in this arena as well.
boydn1 (11-01-2018)
Everyone who has served our great Nation deserves gratitude, but if it looks like it’s used for personal gain, it kinda cheapens it.
Just my .02.
And of course, thank you for your service.
boydn1 (11-01-2018)
To the OP, thanks for your services to our country and check out the Ness stuff. Either that, or install a crash bar and mount some highway pegs to it, there are a number of adjustable sets of mounts/pegs that can be had to get you stretched out (if you like a crash bar on a softail, that is).
Dtown
07-07-2017 07:00 AM
