Softail Slim fog light kit #68000026
I'm about to install the HD fog light kit on my Slim. The instructions are okay, except it doesn't explain where to attach the power to the toggle on/off switch. The instruction sheet shows a box with a White, Black, and Yellow wire. The power is attached to the Yellow wire.
But it doesn't explain where the connection relay is!! Has anyone installed this kit? Can you help me out in locating this box?
It's the rectangular box upper right corner.
showing the diagram with no luck.)
https://serviceinfo.harley-davidson....1?locale=en_US
It would have you connect to the yellow wire. Not sure why you are looking for a relay.
As described in the instructions, if using the yellow wire, the aux-lights only operate with
the headlight on lowbeam. See step 5 under the "Wiring" section. This yellow wire
is from the Headlight connector.
I'll have to see if I can dig up what wire I used for mine & report back.
T.
An easy way to keep the aux-lights on is to use the plug & play harness.
Independent Control Auxiliary Lamp Wire Harness Kit-69200442
Boardtracker has it for ~$25.00
http://www.boardtrackerharleyonline....s-kit-69200442
I didn't use this however... I just looked it up in my Electrical Service Manaual.
What I spliced into was the "Export/Japan Tip light" wire, since it is only hot with Ignition-on.
It is an Orange/White wire.... (and doesn't cost $25)..
hth,
T.
hth,
T.
ChinoSlim (01-13-2019)
Thank you all for responding. I haven't started the project yet cause I'm waiting for powder coat parts. But it appears by your posts that there is a yellow wire coming from the headlight harness that supplies the power. I know it says that in step 5 of the instructions, but it just didn't make sense to me when they showed what appears to be a relay switch.
I'll take things apart in a few days and look for that elusive yellow wire.
I'm not using the standard 4" lamps that come with the kit. I have a set of fog lamps that an old friend gave me years ago. He bought them in 1955 for $5.50 each from Pep Boys. Still in the original boxes. They are 5" lamps with dark amber (almost root beer brown) lamps.
I have been saving them for a special project. I will post a picture once installed.
Thank you again for your help. Deeply appreciated.
...snip....
Looking forward to some pictures.
thanks,
T.
ChinoSlim (12-20-2018)
Ah... I guess the lights have their own housings/buckets and you're getting those
powdercoated black ?
kind of similar to these,
https://www.ebay.com/itm/NEW-1947-19...-/330992868930
T.
T.
T.
T.
ChinoSlim (12-26-2018)
