Help sg front wheel on slim
Old 01-05-2019, 05:23 PM
worked4it's Avatar
worked4it
worked4it is offline
Default Help sg front wheel on slim
My friend has a beautiful 21" 3.5 no abs single disc sinister front rim from his 2011 street glide that I can get next to nothing. Anyone know if it will work on my 2013 softail slim. I am looking to go 21" and would only have to pay to ship it. Hoping someone can help. thanks
Old 01-12-2019, 12:29 AM
Electricfoot's Avatar
Electricfoot
Electricfoot is offline
6th Gear
Haven't done it but I've done research on it because I want to go 21" and fenderless.
So what I've found is as long as it has the correct bearings for your axle diameter all you need is the correct width spacers.
If the bearings are no go, just replace with the correct ones.
Being that his is a '11 and yours is a '13 and they both use a 25mm front axle I'd say you're good to go.
Old 01-12-2019, 05:21 AM
worked4it's Avatar
worked4it
what about rotor size. street glide is a 11.8 and slim is 11.5. wondering if they swap out.
Old 01-12-2019, 07:53 AM
WKNDS's Avatar
WKNDS
WKNDS is offline
Received 1,263 Likes on 931 Posts
Think you'll have contact, but it wouldn't hurt to try since the rotor is only .15" closer to the caliper housing...
You can find the HD-Brembo calipers from the Touring bikes pretty cheap on ebay.
hth,
T.
Old 01-12-2019, 09:08 AM
worked4it's Avatar
worked4it
all in all though you guys feel it can work? I am limited on cash and the price is right.
Old 01-12-2019, 10:36 AM
WKNDS's Avatar
WKNDS
WKNDS is offline
Worse case is you have rotor-caliper contact & just have to run what you got till you have cash to get
a cheap HD-Brembo caliper off of Fleabay. OR (just thinking) you put your stock 11.5" rotor on the
new wheel....
good luck,
T.
Old 01-12-2019, 10:49 AM
worked4it's Avatar
worked4it
thanks
EddieBFoster
08-21-2017 11:37 AM
dharmon012
06-20-2014 06:31 PM
plumberoon
Wheels/Tires
07-21-2012 12:01 PM
hd07glide
12-16-2011 03:35 PM
cHiLi_11
07-14-2008 11:59 PM
Quick Reply: Help sg front wheel on slim
