No i dont have ABS. I understand you only purchased new brake line while throttle, clutch correct? If thats the case it will be awesome. Please be so kind and confirm.
that's correct. Clutch I just adjusted there is enough slack. Throttle cables had lots. If you dont have abs you are good to go! Wiring was no issue also. I moved the turn signals down to forks because I like the look of them off the bars. Good luck!
Will stock riser from Slim work with type of handlebar? I read this riser is somevow different and might not fit some handlebars and with this different diameter for this handlebar in riser area I am not sure if this will fit or not
