EFI to carb
I also have no info, but am interested in this topic. I recently bought my very first EFI bike, but am partial to carbs. I hate the idea of having to buy a tuner to make adjustments that are simple on a carb. I admit that the efi runs nice and smooth and I will probably leave it alone, but...switching to carb has crossed my mind.
Things that I think might be a problem are the sensors and the sort. I dont know the ins and outs relative to the spark/timing etc or if that matters at all if the efi is just unplugged. @DammitDave your bike was a carb model already? If it was I bet sticking with carb will be the most simple route. I hope somebody here with some been there done that will chime in for you.
Since your 03 doesn't have ECU, BCM and such putting the carburetor fuel delivery should be a non issue. Make sure you get a B motor not an A for easier bolt up. The "eBay" motor, long or short block, won't care what fuel system you use, just swap all the original parts from the 03 to the next one. Make sure that what ever block you get is compatible with your transmission, unless the new one comes with it. IAW getting another 88 or 96 will be much simpler than jumping to a 110 or such.
That's pretty much it on the swap! I'm doing mine as we speak. Cut the entire wiring harness off last night and cut out the square tube above the engine. You obviously have to have an intake and the carb- I stand by S&S being the best. Next, the ignition has to be addressed. When it comes to the best Stand Alone Ignition, Thunderheart is it. Easy to use and install. It operates off the crank position sensor and can be tuned, rev limit can be set along with front and rear cylinder spark timing. Super reliable setup. Not my first go at it. I am a fan of carbs and real choppers..to build a real chopper it's got to be carbed (cant hide enough wiring on EFI.) Pull the trigger on it! You wont regret it. Realistically...you are looking at $800-1,000 in parts. Hope this helps.
My new to me 01 Heritage is EFI, all the rest of my bikes are carb. If I unplug the wiring and add the intake/carb and the Thunderheart you mentioned will I get to treat it as a carb bike or will I wind up with a lot of trouble codes/electrical problems? Its something I have been thinking about spending money on the carb swap instead of a tuner before I swap pipes.
Swapped my 05 fat boy to the thunderheart and an SS shorty,I simply unplugged and tucked all wiring and left the fuel pump and assembly in the tank...only “code” I get is the check engine light stays on. Which is nothing to me!
Sanjuro
10-27-2016 11:08 AM
