Stupid Person Question - Starting in Gear
Harley started with the neutral safety switch starting in 1965 when the electric start first came out. My 1966 FL has one. They are a contact switch screwed in to the transmission and not in the clutch handle. Not sure when the clutch switch came out.
Easiest way to see if you "should" have a neutral safety switch is to look at the wiring diagram for your year and model. Very possible someone may have jumped the tranny based switch. They are a pain in the *** when you stall at a stop and have to find neutral!
hdbob2006 (06-14-2019)
I cant speak to the pre 2004 but from 2004 to 2007 to my knowledge all Harleys will start in gear. I owned (04 KL Roadster 1200, 04 RK Custom, 05 Fatboy) would engage the starter in gear. My 2011 RG Custom had a neutral safety switch.
IMO it is the safest and best habit to park your bike in gear so it cant roll off the jiffy stand and always pull the clutch in to start even if you want to find neutral first. If you dont eventually you will do the starter hop forward and hopefully you wont hit someone next to you or drop the bike as Ive seen happen.
My '06 has never had a switch on the trans or the clutch lever. I've always automatically grabbed the clutch before hitting the start switch. Is it that hard to remember? If I had a newer bike that had to be in neutral to start,that would be the first thing I'd 'fix', just like the safety switches on my lawn tractor that I disabled.
Until 2007 model year, a Harley could be started without regard to being in neutral, turn on ignition, press start button, the starter will crank.
The neutral and clutch safety system came out for `07 and later. The transmission must be in neutral, or the clutch lever must be pulled back.
I don`t preach how to ride, but...
You should always park your bike with the transmission in gear...or in neutral.
Whatever you think is best.
You should always start the engine while the transmission is in neutral, or in gear with the clutch lever pulled in, whatever you like to do.
car5car
12-11-2009 10:05 AM
