Question about brake fluid - 2005 FLSTFI
Old 06-15-2019, 02:29 PM
Camiemom's Avatar
Camiemom
Camiemom is offline
Question Question about brake fluid - 2005 FLSTFI
I somehow managed to get a hole in my rear brake line. I am trying to figure out where the hole is before I replace the line, in case it is rubbing on something that is not obvious. The master cylinder says DOT 5, so I assume that is what I am supposed to use, correct? I had read some stuff about changing it to DOT 4......Anyway, is there any way to tell what fluid is in there? I don't want to start another problem. Thanks in advance.
Old 06-15-2019, 06:57 PM
hattitude's Avatar
hattitude
hattitude is offline
Received 7,376 Likes on 4,002 Posts
The DOT 5 fluid is technically better than DOT 4. It has higher dry & wet boiling points and is harmless to paint. Everybody still uses DOT 4, because DOT 5 doesn't play well with ABS brake systems.... SO don't feel bad about having DOT 5...
Here is an easy test to check what you have...
Old 06-15-2019, 07:04 PM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 4,528 Likes on 3,781 Posts
DOT 5. It's like SILICON OIl. Does not hurt the paint. Harley had to go to 3 or 4 when they went to ABS. Not all had ABS but they did not want the confusing. The last thing you want is something that will hurt paint hanging over your tank. Dot 5 is purple but it soon changes to straw and looks like 3 or 4. Just drop some in water if you do not trust what the person before you has done. DOT 5 will not mix and looks like oil in water. Dot 3 or 4 will mix with water. If it is 4, flush it all out good and use 5
Old 06-16-2019, 05:26 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 8,478 Likes on 4,603 Posts
Another fan of DOT 5 here, that DOT 4 is nasty stuff, sucks that ABS must use it.
balloo
03-11-2017 06:53 PM
RENORRIS
01-19-2012 10:19 AM
strippedthread1
Wheels/Tires
10-13-2011 06:39 AM
14U24ME
03-30-2009 07:40 AM
pilot1996
Oil Archive (no new posts)
13
09-21-2005 07:07 PM
Quick Reply: Question about brake fluid - 2005 FLSTFI
