Top of belt rubbing with slammed softail
So my 2004 night train is slammed in the back, pretty well rides on the bumpstops- it's like riding a hardtail lol. The top of the belt is rubbing, so it is now shiny and at the belt is getting very lightly shaved in the process.
I have yet to readjust belt tension after lowering (whooops!) And have put on easily 2500 miles like this. I'm wondering if thus is going to damage the belt to point of failure? I'm going to readjust belt tension and hoping that helps, but not sure how serious this can be considered. I'd really rather not raise it up, and I know there have to be others riding slammed bikes like this too- is a belt more of a consumable now because of this?
Any experience is appreciated!
By dropping the *** you've taken the belt out of it's designed center to center alignment and it's probably rubbing on the swingarm pivot shaft. Yes it's going keep wearing the belt and the shaft, belts ARE NOT designed to wear on the backside, they really don't like that. Depending on how slammed you have it some bikes the belt actually gets stretched at the extreme outer edge of what's left of the arc travel, this really wears them fast, doesn't do your tranny & inner primary bearings any favors either.
Tightening the belt to the proper spec it should be at wont help at all?
Obviously what is going on is not ideal, nor factory intended. My concern more then anything is will the belt get ruined to the point where it's going to fail prematurely from running it this way
The bike has been lowered but level, front is dropped a lot as well.
You are trying to justify your own decisions in your head. Because I ride my bike on the bump stops, everyone must ride on the bump stops. Because of this I have belt damage so the belts must be a consumable. The reality is, most people don't ride on the bump stops. They may ride slammed but not on the bump stops. I agree with TwiZted Biker. It sounds like you want us to tell you what you want to hear.
No one can tell you if the damage to your belt will ultimately result in belt failure. Look logically at your situation. The belt will either remain intact or fail. The fact is the damage to your belt isn't helping it remain intact. Either do something about it or take your chances. You said you don't want to raise your bike. There's your answer... take your chances.
Guys, I appreciate the input, but it has nothing to do with wanting to hear a certain response. I know this situation is not ideal, I have ready stated that...and yes, it may not be common, but I know there have to be others riding around totally slammed. I wasnt looking for the mechanics behind what's happening, but more so experience with this and how it all panned out (I think my original post said that too). I've yet to adjust my belt tension, so i was also curious if that would potentially help or even resolve the situation (I really dont think it will, but doesnt hurt to ask).
Thanks for the input
