Engine swap
I have a 2004 Fatboy. I scattered the engine last week. I am looking at putting a used engine on my bike and found the non counterbalanced engine's to be a lot cheaper than the b engine. Has any one put the non counterbalanced engine in a Softail frame?
Random question here: What exactly occurred during the "scattered" evolution? Did chunks go flying?
Originally Posted by Cliff Taber
(Post 18351460)
Originally Posted by MNtadpole
(Post 18352198)
Originally Posted by QC
(Post 18352212)
It will not work.
Well just a guess the "A: motor uses rubber mounts and then these mount to the fram...the "B" motor mounts directly to the frame...The trans for the Softail frame also mounts diffently and the "A: motor trans also has the swingarm mount in it...I would think by the time you are done spending on everything you will need to change...you might as well get the corret engine
Originally Posted by Scudda
(Post 18352576)
Originally Posted by XARAN
(Post 18352752)
+1. And if you try to mount it with out the rubber mount (to let the engine move) with a non counterbalanced engine the vibration would be strongly fely in the bike and may even end up cracking the engine cases
"strongly feel the vibrations",but no,it didn't cause any 'cracked cases'. But, to put it simply, as QC said "It won't work". This forum can really be a trip sometimes! |
With all of the above said, a Softail engine should be findable at a reasonable price.
Not hard to find at all
88B motor |
© 2024 MH Sub I, LLC dba Internet Brands
