Go Back  Harley Davidson Forums > Harley Davidson Motorcycles > Softail Models
Reload this Page >
Softail Oil Check - Jiffy Stand or Standing Up...?
Notices
Old 06-24-2019, 07:34 PM
writer1973's Avatar
writer1973
writer1973 is offline
New Member
Default Softail Oil Check - Jiffy Stand or Standing Up...?
I've got a 2012 Fatboy Lo with an aftermarket RIGID oil dipstick. On the jiffy stand, it shows more than a quart low (both hot or cold). Standing up level, it shows full (both hot or cold). I called the dealer (where I picked it up from) and they said that Softails with rigid dipsticks should be checked standing up. Then I did some research here on HD-Forums and there's someone quoting the 2008 FLSTC official Harley manual that says check on the jiffy stand:
"For preride inspection with the vehicle on jiffy stand on level ground, remove and wipe off the dipstick. Install the dipstick back into the oil tank."
WTF? Which is proper? Are rigid dipsticks that different from the floppy ones? Can't believe this is my fourth Harley and I'm asking this question. Thanks in advance for helping my dumbass out.
Old 06-24-2019, 09:56 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
OldEnuf2NoBtr is offline
wyndnface (06-25-2019)
Old 06-24-2019, 10:03 PM
bad tappets's Avatar
bad tappets
bad tappets is offline
My ‘06 is on the side stand. However different model years have different procedure. Check the owners manual for your model.
Old 06-24-2019, 10:28 PM
writer1973's Avatar
writer1973
New Member
Originally Posted by OldEnuf2NoBtr View Post
So... you don't know either. Maybe someone will come on here and help us both out.
The following 2 users liked this post by writer1973:
Big Mule (06-25-2019), rubberfrog (06-24-2019)
Old 06-24-2019, 10:38 PM
writer1973's Avatar
writer1973
New Member
Originally Posted by bad tappets View Post
My Ď06 is on the side stand. However different model years have different procedure. Check the owners manual for your model.
Thanks but the problem is that this is not the stock dipstick... the dealership said the rigid dipsticks (aftermarket with the temp gauge on top) require the bike to be vertical to read. I've never heard this before and can't verify on the forums.
Old 06-25-2019, 01:47 AM
Bone Doc's Avatar
Bone Doc
Bone Doc is offline
Received 1,331 Likes on 861 Posts
Hopefully, the manufacturer of a dipstick places the calibrations at the appropriate place on the dipstick so it gives an accurate reading regardless of whether it is a rigid dipstick or not. That may not be the case. Nonetheless, if you tattoo your dick with graduations for oil level you can use it to check your oil.
The 2012 Softail Owner's Manual says to check the oil on the jiffy stand.
Old 06-25-2019, 03:47 AM
Ridetothehill's Avatar
Ridetothehill
Ridetothehill is offline
One Of The Regulars
Couldn't you use the stock stick, if you still have it, to get to the proper level; and, then check it with your new stick?
The following 3 users liked this post by Ridetothehill:
DrPlastic (06-25-2019), Fatboy Brian (06-25-2019), Hdbkstl (06-25-2019)
Old 06-25-2019, 04:48 AM
IronAss's Avatar
IronAss
IronAss is offline
Received 1,136 Likes on 595 Posts
Originally Posted by Ridetothehill;[url=tel:18354125
18354125[/url]]Couldn't you use the stock stick, if you still have it, to get to the proper level; and, then check it with your new stick?
You beat me to it. If he no longer has the stock stick Iím sure someone will let him stick their floppy stick in his bag so he can compare.
Old 06-25-2019, 06:50 AM
j33ptj's Avatar
j33ptj
j33ptj is offline
Don't even have the original oiltank,... it is all a guess!
:-D
Old 06-25-2019, 09:45 AM
hattitude's Avatar
hattitude
hattitude is offline
Yes they are.....
Just think of the geometry of what's going on....
For your reference:
Both my softails have rigid, straight dipsticks and say to check oil with bike level..
My '16 touring bike has a "floppy" dipstick. It has two scales. One for level and one for jiffy stand oil checks (my '12 touring had the same)
IMHO..... If we assume your aftermarket dipstick is marked accurately, and since you ride your bike in the upright position... I'd check the oil with the bike warm, level and keep it just of the full mark...
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
