I turned my 2016 Fatboy S into a bagger
I turned my 2016 Fatboy S into a bagger Everything was going good till I put a SMT Machine 26 inch front tire on now my bike is starting to wobble around 75 to 85 MPH I am currently getting a steering dampener on and I put in thicker fork oil and that helped, does anyone have any other ideas?
The following 2 users liked this post by KUMA480:
JUICEBOX6257 (07-23-2019),
RBEN (07-07-2019)
Some things were not meant to be. Can't see the back tire but assume it's the fat 200 tire with now a much skinnier front. When you have made all those geometry changes you now have become the R&D test pilot and now learn why certain extremes might look good static, but perform badly.
EDIT PS, my sig picture is what a bagger looks like.
hdbob2006 (07-10-2019)
Check the "fall away" its the most common cause of wobble.
But its probably because of the change in wheel diameter you have changed geometry.
I dont think Id feel safe at speed on it if it takes a damper to hold it steady, better to make the modification to the larger diameter wheel correctly and correct the rake, either triple trees or alter the neck.
Wobble at 75+ = death wobble
Sorce (07-23-2019)
The following 2 users liked this post by Fatboy16S:
KUMA480 (07-14-2019),
soldierbot (07-09-2019)
