Heat Shield
Old Aug 25, 2022 | 07:45 PM
Wagondog's Avatar
Wagondog
Thanks Hatitude
That Pingle petcock was a hurry up job done in the rain and I never went back to the carb nipple to cap and get that hose out. I plugged the end......folded the end over and tie wrapped it so I may have a little vacuum leak.
All the responses I get here give me knowledge.
Old Aug 26, 2022 | 05:03 PM
Wagondog's Avatar
Wagondog
Vipers
Does it make sense that it would be electrical even though every time it happens I am rolling on the throttle? It can be doing 40 mph with a little throttle roll, a little throttle coming to a stop, or a little roll starting from a light.
The throttle is always involved, she gives a little swish sound in the carb then shuts down as I am rolling the throttle. I can set her on the jiffy and she will idle forever without a burp.
on a little family vacation now but my hands cant wait to get home and fix her up
Old Aug 26, 2022 | 06:18 PM
hattitude's Avatar
hattitude
Originally Posted by Wagondog
Vipers
There's only one way to tell for sure......
Next time it fails, check to see if you have spark....
Old Aug 26, 2022 | 09:20 PM
Vipers Harley's Avatar
Vipers Harley
Vipers
As mentioned check for spark when it happens. I found the relay issue on the road king I worked on by testing the relay as soon as it shut down on me, left the seat loose and road county roads till it died then tested the relay and it was open. It would sputter a little almost like a fuel issue but it was from losing fire that was causing that. There was no shorts or issues other then just a tired relay, (It's a 1995 evo)
So once I replaced it I never had it happen again nor has the owner this was 4 years ago.
Worth looking into for sure.
Old Aug 29, 2022 | 03:48 PM
Wagondog's Avatar
Wagondog
Default Thanks
Thank you all for the replies and possible solutions to my 2000FLSTC unpredictable stall.
I replaced the stock coil with a Daytona coil, so far the problem has disappeared. Perhaps more riding will prove success or not.
I am going to replace the relay suggested by Viper once I find a replacement as well.
Thanks.....you guys are great!
Old Aug 29, 2022 | 03:54 PM
Vipers Harley
That's a good sign thus far. Glad to hear your gaining on the issue.
Old Sep 1, 2022 | 09:38 PM
Wagondog's Avatar
Wagondog
All is good with the 2000 STC and her unpredictable motor shutdowns. It happened so infrequently that finding the problem by riding was next to impossible. One suggestion given here was replace the coil. I used a Daytona High Output coil from JP Cycles for about 100 bucks.
Installing the coil took 15 minutes.....getting the small screw holding the coil cover on took 2 hours. I guess any fastener in for 22 years can be tough coming out but I was tougher than the screw.
Finally had time to put on substantial miles and happy to report the new coil not only stopped the shutdowns but seems to have given the old girl new pep.
Thanks for all the suggestions.....especially Viper Harley and Hatitude
Gabes58
May 26, 2021 05:34 AM
Gasman1976
2014-2024 Touring Models
Jun 24, 2015 03:53 PM
mdanehart
EVO
May 3, 2013 04:08 PM
FenderGuy53
Mar 27, 2012 08:13 PM
cliff7122
Jul 21, 2006 12:19 PM
