For those Softail owners who travel or bring passengers rarely - a relatively affordable Tour Luggage / Backrest Solution
My 2023 Breakout 117 is used almost entirely for short rides and day trips, BUT I want to be able to do the occasional overnight trip to a nice riding area in the nearby mountains too far away for a day trip. I also want to at least once per year do a multi-day vacation tour. I would like to also offer my wife a backrest the few times she expects to ride as a passenger.
The Breakout is of course not designed for either passengers or long distance touring as a primary mission. Plus, its long and low “dragbike” styling would be seriously hurt by adding permanent luggage capability. It’s NOT a ‘bagger”, and I don’t want a bagger for three good reasons:
Objectives: Based on all the above, I thought for quite a while about what my OBJECTIVES are for a temporary, use-when-needed luggage and passenger capability, and came up with this list:
Although I considered a number of solutions, after considering all the above, I ultimately decided that the best solution for ME might be a “dry bag” (often used in kayaking and other water-centric activities), fastened to and supported by a SHORT sissy bar (short to keep as much of the long low Breakout look as possible, and to enable carrying the dry bag horizontally, like cowboys in The Old West used to carry bedrolls on their horses. One unique advantage of a good dry bag is that its actual packed “volume” can be CHANGED. i.e. it can be fully filled and folded shut, OR partially filled and then sealed by folding the mouth closed using more folds. This means that, within reason, it is only ever as “big” as your current trip requires! One advantage of the sissy bar approach to luggage is that a sissy bar with a backrest pad can also make your significant other notably more confident and comfortable when she rides as your passenger. Harley-Davidson does offer a dry bag solution (the HD Overwatch Dry Bag) that can work with a sissy bar, but after examining it, I ruled it out because: - It is designed for VERTICAL use, so needs a HIGH sissy bar, which I do not want - Its 2 external thin pockets have exposed zippers and are NOT waterproof, making those pockets useless for wet riding - The price, at $215 Canadian, is over double what several good non-HD dry bags cost The Dry Bag: Although I have other existing dry bags from when we tried kayaking, they were way too small for this use. I searched the amazon.ca site and selected this Kronox bag: https://cimg5.ibsrv.net/gimg/www.hdf...6088aeac08.jpg I selected this specific bag for multiple reasons, despite it being larger than ideal:
The Sissy Bar: In an earlier posting on the forum, I mentioned that the genuine HD detachable sissy bar solution for the 2017 Breakout 117, including the sissy bar, the backrest pad, and the correct docking kit, costs over $500 Canadian with tax here in Canada - IF you can qualify for free shipping. That seems a bit much given my occasional usage plans. On Amazon.ca, I was able to buy a detachable sissy bar including a backrest pad, for $245 Canadian = $181 US taxed and delivered. Here is a photo: https://cimg2.ibsrv.net/gimg/www.hdf...1d9fae1406.jpg Its key features are:
Summing up the weight of this luggage solution, before adding the luggage into the bag: Sissy bar assembly = 6.9 lb Docking hardware kit = 0.5 lb more than the OEM bolts it replaces Kronox dry bag = 2.5 lb Total weight = just under 20 lb plus whatever little weight the tie-downs add when cut to ideal length. Here is how the low, black sissy bar looks on my Breakout: https://cimg8.ibsrv.net/gimg/www.hdf...8a227b998.jpeg Here's a photo with the bag in position (not yet secured y lash straps in this photo) https://cimg0.ibsrv.net/gimg/www.hdf...fa004c995.jpeg Here's another view https://cimg5.ibsrv.net/gimg/www.hdf...7be43662e.jpeg And here's a photo that shows the width of the bag versus other items on the bike: https://cimg0.ibsrv.net/gimg/www.hdf...3050f629c.jpeg Notice:
Lashing straps: When I went looking for “lashing straps” at the Home Depot website, I discovered to my pleasant surprise, that I could buy a pair of black 8’ long straps with orange trim colour! However, they do NOT come even close to matching the HD orangy-red paint trim on my Breakout. :( https://cimg7.ibsrv.net/gimg/www.hdf...a6aa13005.jpeg The pair cost only $14 Canadian = $10 US, and I was able to cut them to the specific length I needed for my use! Lashing straps come in two basic varieties: those that have big metal ratchet mechanisms and those that have much simpler metal “jaws” that simply clamp onto the strap at the point that you want them to do so. I wanted the simpler ones because (a) they are much simpler to use, especially when it’s cold or wet outside, and they won’t damage the bag’s material or the sissy bar if they contact either. These have the “simple jaws”. Perfect. They are more than strong enough too despite the modest price. The working load limit is 500 lb, and the breakage limit is 1500 lb, so they are overkill for my usage. And the simple metal jaws hold well against slippage if you use them correctly. On this project, I’m pretty pleased with both the total cost and the end results. Hopefully, it might help others on the forum. Jim G |
I’d replace the straps with ROK straps. Their elastic section works a treat at holding tension as the bag settles down.
You can buy a quick release luggage rack for the tail. Then you can plunk the bag fore and aft. It’ll be more secure and stable that way. Let the bag sit on the pillion seat and rack. Bonus, it makes a decent backrest for you. https://cimg0.ibsrv.net/gimg/www.hdf...cb9c4125f.jpeg https://cimg1.ibsrv.net/gimg/www.hdf...735c24c41.jpeg https://cimg2.ibsrv.net/gimg/www.hdf...4e3bf97f7.jpeg |
:icon_eek: And here I thought I tend to over analyze simple problems. I just bought a sissy bar bag and strapped it to my sissy bar.
Originally Posted by KK0G
(Post 21622014)
(Post 21622014)
- A bag fastened to a sissy bar should work, but - I don't have a sissy bar nor a waterproof bag, but - You can't fasten a sissy barto a Breakout without first buying a docking kit, - But the first non-HD docking kit literally broke during installation - So, I had to pay HD's inflated price for a docking kit, and WAIT for it to arrive - Harley wanted over $200 CDN for its bag, and it's not even waterproof . .. You see how it goes . . . Maybe my write-up will save some other forum members time, money, and frustration. Jim G |
I have had a Kury bag for years that sits on the luggage rack (for two-up riding/very seldom) or as in my case mostly solo riding it sits on either the passenger seat or the rear fender rack with the quick detach passenger back rest attached. When at a destination I can remove the passenger back rest and luggage and have my sleek solo Softail Springer "look". The Kury bag is water resistant although not a boating type bag and it has a very nice rain cover that is easy to install.
Saddlebags.
Beautiful bike!
I have a couple of Kriega dry bags left over from when I used them on my previous touring bike, a Ducati Hypermotard (yes that’s right! A great bike but a small tank). https://kriega.us/usdrypacks-2 The bags attach to webbing loops that run under the seat or attach to the subframe to quickly take them on and off of the bike, and the bags are modular in that multiple bags will attach to each other. They work great and are well made, and will work on any bike. Now I use them on my Road King. Here are the same bags being employed on two very different bikes: https://cimg0.ibsrv.net/gimg/www.hdf...7d07b2952.jpeg https://cimg2.ibsrv.net/gimg/www.hdf...8c3b02cea.jpeg |
Holy long post Batman...lol. You must be some type of engineer Jim? That was one of the most detailed/ thorough posts I think I've ever seen. Whatever solution you come up with be aware that when you travel with a woman you're going to collect things along the way...pretty much every where you stop they seem to get something. I thought men were the hunter/ gatherers. I always keep a couple bungee cords in the bag to hold down the extra crap they buy....just something to keep in mind.
Originally Posted by Screamin beagle
(Post 21639994)
Jim G |
© 2024 MH Sub I, LLC dba Internet Brands
