Need help identifying this exhaust
Old Jun 5, 2026 | 08:41 PM
Softailrider22634's Avatar
Softailrider22634
Stage I
Default Need help identifying this exhaust
I’m looking at this exhaust and I’m not sure if this exhaust is for a dyna or softail on the back of each of the mounting brackets of the slip on it has the number d560 stamped on it but I can not seem to find any numbers on the head pipe itself
Old Jun 6, 2026 | 06:58 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Judging by the rear mount I would say they are for a Softail.. The shorter ones resemble older Paughco's..
Old Jun 6, 2026 | 11:35 AM
bustergut's Avatar
bustergut
D560 mentioned here:
File Type: pdf
Old Jun 6, 2026 | 07:04 PM
hattitude's Avatar
hattitude
I have used Vance & Hines exhausts on three Softails, and one Dyna.
I currently run V&H Straight Shots on two Softails.
I agree with both the posters above.
I believe the longer ones in the center are a Vance & Hines exhaust product, and further believe them to be a set of V&H Straight Shots, as suggested by bustergut's install instruction attachment showing the bracket you mentioned. Because of the two-piece heat shields, I believe them to be an older set of Straight Shots.
The smaller pipes, although I can't see the mount for the farthest right, short pipe (which is most likely a rear cylinder header) I believe are a different manufacturer than V&H. I can see why 98hotrodfatboy thinks they are older Paughco's. Based on what I can see of them, I wouldn't dispute that call.
Roystan
Exhaust System Topics
Jul 11, 2021 08:29 AM
TedMan
EVO
Feb 2, 2020 07:49 AM
Mceh0495
Jun 24, 2019 10:20 PM
cbrittingham
Dec 6, 2013 07:07 PM
SteveB1971
May 5, 2013 02:02 PM
