Stuck fuel sending unit?
I read the fix for it but is there any way to knock it loose without tearing the whole thing apart?
Been using the odometer for fuel stops.
Thanks MikeM
I think I have a stuck float in the sending unit. 05 Fatboy Injected.
Thanks MikeM
My fuel gauge works, but I don't pay any attention to it. I use the odometer, to judge when to fuel up.
Tom.
I almost wish there was a clean way to remove it completly and cap-off the resultant hole. I don't know (yet) whether the float feeds the low-fuel idiot light (also useless) and the '08 version of remaining miles to go which is a button select past the two trip odometers.
If I knew for sure that the float doesn't feed all these other displays, I'd be on a path to remove the analog fuel gauge. I'm still waiting on my '08 service manuals (including the electrical & suppliment) to help answer for myself.
Some folks claim that occasionally the gauge will work itself free again. Which is also saying that it will occasionally get stuck again. You only real choice is to tear into it and do the documented bends and sandingto acheive a more permanent fix.
Good luck.
The gauge has been very accurate....but I stillrely on mileage for when to stop for gas.
Check out these posts:
https://www.hdforums.com/m.asp?m=223...page=1&key=
I fixed mine about a year ago now. 2003 NT.Still working fine.I replaced the orig. fuel gauge with a Kuryakyn: http://www.kuryakyn.com/products.asp...ey&ci=2696
You gotta LOVE this forum!
-regards
