Anatomy of a headlight
Old Nov 12, 2007 | 04:32 PM
erockguide's Avatar
erockguide
Default Anatomy of a headlight
I have an '07 Softail Custom. Lately I have noticed that the front light shakes like crazy, and I really notice it at night because all the road signs flicker really bad thanks to the bad shaking it does. It feels secure, but I can wiggle it slightly by hand. The main piece holding it the bike is solid, but there are two pieces that seem to attach inside the light, almost like a hinge, and that is the part that moves.
I have attached a picture for reference. The part that says no movement is where it is attached to the bike. The part that says "movement" is where a piece goes into the inside of the headlight and when I manually try to move the headlight up and down, is where it looks like the swivel is coming from.
Is this normal? I don't see other bikes headlights shaking so much. Is there a way to tighten this up? It's annoying at night.
Thanks
[IMG]local://upfiles/24973/401241585B494329B66DBA336636D622.jpg[/IMG]
Old Nov 12, 2007 | 05:02 PM
BoneCrusher's Avatar
BoneCrusher
Default RE: Anatomy of a headlight
Check out this thread
https://www.hdforums.com/m_1386317/tm.htm
Old Nov 12, 2007 | 05:10 PM
serge627's Avatar
serge627
The light on my Deuce does the same thing, thanks for the link.
Old Nov 12, 2007 | 05:11 PM
anubisss's Avatar
anubisss
I've had a lot of different bikes (most metric) and the lights have bounced around like crazy as well. d
Old Nov 12, 2007 | 05:57 PM
Waltman's Avatar
Waltman
Remove headlight, dissasemble and reassemble and retighten, most likely something is loose.
Old Nov 12, 2007 | 06:09 PM
erockguide's Avatar
erockguide
I think 06Deuce has it right, in the other thread that you linked to. Thanks for the link. I am going to try that mod and I bet it will fix it. Imagine that, $6 and it works. Harley probably would charge 2 hours labor. HA!!!
Old Nov 12, 2007 | 06:50 PM
beard63's Avatar
beard63
I had the same problem, so I removed the headlight and cut piece of 5/16 rubber hose and installed it between the bracket and the bottom of the headlight. Problem gone and very cheap fix!!
hemi1300
Oct 10, 2018 02:26 PM
06BlackWG
Oct 6, 2013 07:02 PM
kk6pg
Aug 13, 2009 10:49 PM
Yonaton
Jan 11, 2009 05:51 PM
abie
Sep 27, 2007 10:09 PM
