Re-use Kuryakyn ISO grips?
Is there any chance I'll be able to remove my left-hand side Kuryakyn ISO grip that I glued on (with glue supplied with grips) and re-use the grip with new bars? I have not checked with Kuryakin, but it seems that the rubber insert should be replacable.
Thx, jmc |
RE: Re-use Kuryakyn ISO grips?
I'm changing my bars this Sunday and will try to reuse my ISO grips. I'll let you know how it turns out.
I was able to reuse mine when I change my bars. Don't know if that is the norm or if I was just lucky.
Good luck! |
Mine came off before, It was glued and I was riding home from work... It was raining pretty
bad then I felt the grip slip... Now I use a double sided tape just like you would a golf club grip... It works better then the glue for me :0) |
i was able to twist it back and forth and it got gradually looser and came off after a few times fully intact
If none of that works write Kuryakyn and ask what kind of solvent is safe fore their glue. Or try nail polish remover. Reason you should ask them first is so you don't pooch the finish or the rubber.
Sounds like it's do-able and there's a few techniques that work. I just hate to waste 'em not to mention I don't think they'll sell a left side single
© 2024 MH Sub I, LLC dba Internet Brands
