Springer questions
Hi folks.
I might be "falling into" a deal to get a Springer Softail. This will be my first Harley. I currently ride a Kwacker, so Im kinda exited. My question is, how does the springer ride? Is there anykind of problems asociated with a springer I should be aware of? Do's/dont's? How dificult would it be to swap out the springer for a regular front end if I didnt like it? Thanks for the coming help. |
RE: Springer questions
I have a 92 springer and the only problem that the springers have are the bearing in the steering head need to be replaced every so often. You'll feel a flat spot when you turn the handlebars. It wasn't too hard to replace just had to cut out the races with a dremel. Other than that you will enjoy it.
My first Harley was a Springer. I bought it in 05 and it has given be excellent service.
All I can relate to is the XBones which is configured like the Springer Softail. The Springer is a very enjoyable ride. In parking lots, etc. you can tell that the Springer is up there since it is one of the heavist front ends HD makes, but on the road it is very stable. I live in East TN and love to ride the curves up at Deals Gap, etc. The Springer takes to the curves like a duck to water. I was very impressed the first time up there. There is a little more maitenance on the Springer front ends, but nothing huge. The newer Springers have less issues with the head bearings than the older ones. Tells one thing, the Springer is an attention getter. Everywhere I stop, people comes over to check it out or yells "nice bike". They just have a great look to them.
Love mine, very stable handling given the extra weight up front. And you cant beat how purrrdy they are.
Thanx guys. I guess there arent really any issues. Good to know.
What about changing out the front end? Can you swap out a springer for a standard front end pretty easily? |
ORIGINAL: *J* Thanx guys. I guess there arent really any issues. Good to know. What about changing out the front end? Can you swap out a springer for a standard front end pretty easily? As for swapping out front ends as long as you picked a front end for the correct year softail, I assume that is what your looking at, I don't think it would be an issue. As far as it looks in that manual the neck of the frame is the same and it is just a matter of which frontend they hung on the bike. What kind of springer you looking at? |
Change the front!!! Don't do it, you'll regret it in the long run.Very neat and different style, classic is all I can say. Just my 2cents
Had a 95 Bad Boy. Loved the Springer. It was lowerd and still road great. You might hear the spring when you ride but thats normal.
ORIGINAL: skullhead What kind of springer you looking at? |
© 2024 MH Sub I, LLC dba Internet Brands
