lowering a 2008 fatboy
Old Jun 24, 2008 | 06:46 PM
garryb's Avatar
garryb
Default lowering a 2008 fatboy
has anyone lowerd there 08 fatboy? i wont to lower mine 1.5 to 2 inches i have orderd the parts from J&amp\\;P Cycles but dont know if i can do it myself. is there anytools i will need from the dealer. or do i just pull the shocks off put the new parts on the them and put the shocks back on?
Old Jun 24, 2008 | 09:17 PM
mjd325is's Avatar
mjd325is
Stage II
Default RE: lowering a 2008 fatboy
You'll need&nbsp\\;a shop press to do it.&nbsp\\; I did mine last week (2007 FLSTF) with the Progressive Lowering Kit.&nbsp\\; After you compress the shock (be careful!) remove the retainer clip w/ a pick, then the inner spring assy comes out and you replace the bolt with the one in your kit.&nbsp\\; Pretty easy if you have access to a press, if not progressive makes a spring compressor for around $90, I saw it in J&amp\\;P.
Udawg
Jul 8, 2014 10:42 PM
roysays
Dec 19, 2008 07:25 PM
texfatboy
Sep 22, 2008 11:44 AM
dually1996
Welcome Area Only
14
Oct 16, 2007 07:55 PM
girliebiker_60
Sep 17, 2007 07:12 PM
