Kuryakyn flush mount gas cap and gauge
Anyone? I would love to see pictures. I want to add a locking gas cap, have one installed on my Sportster and love it. How do charging system and fuel gauge work? Any problem? The HD flush mount looks good too, may also consider that. Thanks Alex
http://128auto.com/cover/gascap.jpg |
RE: Kuryakyn flush mount gas cap and gauge
There's been a couple of posts on here saying the harley caps don't mount completely flush. \\;
Thanks for the heads-up, that sucks! [:'(]
ORIGINAL: wiseguy2day There's been a couple of posts on here saying the harley caps don't mount completely flush. \\\\\\; |
ORIGINAL: wiseguy2day There's been a couple of posts on here saying the harley caps don't mount completely flush. \\;\\\\\\; |
ORIGINAL: 128auto Anyone? I would love to see pictures. I want to add a locking gas cap, have one installed on my Sportster and love it. How do charging system and fuel gauge work? Any problem? The HD flush mount looks good too, may also consider that. Thanks Alex Just installed the Kury flush mount informer on my softail. Has volts reading and fuel reading with warning light. Works well , but unless you take the time to bend the float rod to make the readings correct it will read the same as the stock gauge, even if you drain the fuel down to one gallon to calibrate the gauge. \\;By that I mean if you had two gallons left in the tank when the fuel light was on with the stock fuel gauge, you will have two gallons left with the Kury informer also. Other than that it reads instantly and has a neat light show when the key is turned on. Rumor has it the HD flush mount led unit is somewhat lacking in durability so I stayed away from it. Don't know how much fact there is to this. Ron http://128auto.com/cover/gascap.jpg |
© 2024 MH Sub I, LLC dba Internet Brands
