Conflicting Information on Exhaust
I tried a search and didn't have much luck...
I am thinking of installing V&\\;H Long Shots on my 08 Deluxe. I have heard some people say I will need a tuner or ECM program\\; others have said since the 08 has O2 sensors, I am fine without. I am already running a high flow A/C. Which is right? |
RE: Conflicting Information on Exhaust
I have em on my 07 DELUXE with a COBRA DFO
AND no 02s......... |
If you change one or the other by itself Breather or exhaust you are ok. If you chane both out then you will need some kind of fuel management system.
i have a 08 fatty and i ordered v-h big radius and v-h fuel pack and the arlen ness big sucker and the big radius came with 02 censor mounts. i think it is bull s%#@ we have to have the epa messing with us.
If you change your exhaust (full exhaust) or your AC you are suppose to run a fuel management system or get the ecm reflashed.
If you just change your slipons (exhaust) then you don't need to do anything. |
I have heard it all. because of the lean burn you should get a fuel management even on a stock bike and a dyno-tune.
Just plug in XIEDS
XIEDS is a patch until you can afford to do it right.
I punched out the baffles on my stock pipes. The bike ran like crap until I had the stage 1 done three days later. It felt like it lost 20% power.
ORIGINAL: rockerhead Just plug in XIEDS |
© 2024 MH Sub I, LLC dba Internet Brands
