NEED HELP springer
i have a 1998 fxsts. its my first springer but it feels like it shakes a whole lot more then it is suppose to. i can even hear the springs chatter against each other. is this normanl? what could cause this? thanks alot, Brian Brphd1@yahoo.com
You'll hear clanging, banging and squeeking....Is it a shake or a front end wobble..For a wobble.....Check the front tire for wear, check the spokes, and check the head bearings.
Also you didn't mention what any other bike was...An evo inherently will shake more than a twin cam. |
I have a 07' Springer and there is no wobble and no banging.....
I have an 06 with just under 15K. No maintenance of the front end except inspections and bearing lube. I have no odd noises that I am aware of.
Have it looked at. Head bearings or other adjustments/replacements could be necessary if what you are describing is abnormal. You likely have more going on than just this but I have heard a few people say they bend the internal springs to keep them tight against outer springs and reduces twang from them but performance is unaffected. |
Mine is an 04. The only thing I hear is the shock compressing on big bumps and no shake at all.
I've got an '06 and noticed a lot more "pogo'ing" (for lack of a better term) when cornering hard just before my 10k. The actual 10k service involves completely taking that front end apart and re-assembling for proper specs. Once that was done, everything was tip top again.
Has your Springer ever had it's front end adjusted / re-assembled? |
wheel fittment, need help!
alright, here it is. i have a 21'' HD Lightning Star front wheel that came off of a 2000 fxst softail standard. I own a 1998 fxsts softail springer. will this wheel bolt right up or do i have a change the hub out or what. i keep hearing different stories. can anyone help? thanks alot! , brphd1@yahoo.com
i have always herd you don't change the tire size on springers. they are ment for the size they are built for dealing with the rake and all. i would dig deep to get the right answer for that one.
Originally Posted by huddy
(Post 5087681)
Zach has a bunch of info together in a thread, here: https://www.hdforums.com/forum/softa...ht=springer+21 |
I can't say for sure but reasonably confident that all FX Springers have a 21" front wheel. That being the case I think you are good to go. Only variance would be the spacers if new wheel hub is different width than stock.
Originally Posted by brphd1
(Post 4176981)
© 2024 MH Sub I, LLC dba Internet Brands
