Removing button seat and rack on 08 Deluxe
Rack/pillion removal
If I'm not mistaken (it's been a year since I had the rack off) you will drop the nuts and and a metal reinforcement piece when you take off the rack bolts. I think I accessed them again to put them back on by removing the ECU plastic tray? I take the pillion off but I leave the rack on. I bought a fender bid for the deluxe that I leave on the bike. The rack's bolts go through it so the rack is on top of the bib. When the pillion is off the fender has a finished look to it and the crappy protecto plastic can be removed. Pillion goes right on top of the rack and bib when that's in use.
I removed mine with no problems. When you take off your passenger seat, turn the seat over and look underneath it. You should see a chrome plug stuck in a little holder that will cover the bigger hole that will be in your fender once you remove the seat and rack. Harley also makes the plugs for the smaller holes in the fender. I don't remember the part number right off hand, but do a search and you should be able to find it. They make both chrome and black plugs. There is a film over your fender that is under the passenger seat to protect the fender from scratches. I removed the film from my bike because I never put the passenger seat back on, but if you wanted to replace it, Harley sells that too. The rack you see on my bike is not the stock rack. My aftermarket rack uses the bigger hole left by removing the seat and I got the chrome plugs I mentioned to plug the two smaller holes.
I have an '07 Deluxe and removed the rack and pillion seat. Seat comes off easy enough and the rack as well. I can only speak for my '07 but I had nothing drop. The single bolt hole in the middle of the fener is threaded. The only thing you do not want to do is remove the plastic washers/retainers on the seat bolts. They hold the bolts in place and I have read on other posts that if these come off the bolts drop and they are a pain to put back in from beneath the fender. As for looks without the rack and seat it is ace! I used a bib and liked the look until I put my bags on. Once the bags were on I wanted a bit more above the fender for asthetic reasons so I put my rack back on. I think there are some before and after style phots in my album. Good luck and enjoy your ride!
I removed mine with no problems. When you take off your passenger seat, turn the seat over and look underneath it. You should see a chrome plug stuck in a little holder that will cover the bigger hole that will be in your fender once you remove the seat and rack. Harley also makes the plugs for the smaller holes in the fender. I don't remember the part number right off hand, but do a search and you should be able to find it. They make both chrome and black plugs. There is a film over your fender that is under the passenger seat to protect the fender from scratches. I removed it from my bike because I never put the passenger seat back on.
Mystic,
I just want to say that you got one sweet Deluxe! Nice color choice too!
Thanks a bunch Niddit. Just last week I had the front end chromed out, added the chrome front brake caliper and steel braided cables. I've also added the chrome switch housings since those pictures were taken.
Have you seen the latest American Iron mag? I'm thinking there is an old Sportster in it with bags like yours. Looks great! You have a great color too!
