Side mount plate for FLSTSC
Old Apr 12, 2009 | 08:33 AM
lowrider284's Avatar
lowrider284
Default Side mount plate for springer?
Looking to get a axle mount vertical plate mount for my 06 FLSTSC. Doesnt have to have a braje light or be lighted. any suggestions on what product to go with? also, can I install without removing the wheel, Ive heard with certain mounts you can just remove the nut and pin and replace one of the washers
Old Apr 12, 2009 | 08:40 AM
P'colaHarley-17RGS's Avatar
P'colaHarley-17RGS
I'm looking to, for horizontal mount for my 06 Fatboy, but everything I've found is so damn expensive.
This is a good example...
I like this setup but called to ask for what parts I'd need and how much it'd cost and it was over $300
that's insane.
If you find something pm me and let me know and if I find anything else I'll do same... thanks.
Old Apr 12, 2009 | 08:42 AM
lowrider284
yeah, i want to go with one of the cheap axle mount ones from road6customs, im just not sure how involved the install will be
Old Apr 12, 2009 | 08:49 AM
Bluzmn59's Avatar
Bluzmn59
I would just point out that you might want to go with a horizontal side-mount instead of vertical as a few states (FL, for example) have outlawed the vertical. To me, anything I can do to avoid unwanted attention is a good thing.
Old Apr 12, 2009 | 08:50 AM
lowrider284
a buddy of mine has the vertical and we've ridden all over nj and ny state, never had a problem
Old Apr 12, 2009 | 08:54 AM
lowrider284
i was just on another forum site and saw that one of the guys custom made a plate mount the goes right in back of the axle and looks like an axle mount but it actually bolts onto the belt guard tabs. anyone see somehting like this before?
Old Apr 12, 2009 | 06:18 PM
lowrider284
Just went out to the garage and checked out the axle....it looks like I can take out the pin and take off the nut and just replace the washer with the plate mount....can anyone confirm this? Thanks
Old Apr 12, 2009 | 06:27 PM
anubisss's Avatar
anubisss
Yes, you can do that.
Old Apr 12, 2009 | 06:32 PM
lowrider284
Great.....so the tension from tightening the nut will keep the mount from drooping down? (I notice there's no stop or rest spot on the mount or the axle to keep the weight of the mount from bringing it down)
Old Apr 12, 2009 | 06:34 PM
TIPN8R's Avatar
TIPN8R
The Road 6 Custom is an easy install.
Tell you what, being you are only less than 30 minutes from me, if you go with the Road 6 set-up, I'll come down to you and help you throw it on. It's simple!
Let me know.
