Scraping Floorboards
Old Apr 28, 2009 | 09:56 PM
snowmass's Avatar
snowmass
Originally Posted by XARAN
One of the guys we ride with installed 2 nut and bolt combos using acorn nuts on the bottom outside edge of his floor board to scrape first and save the floor board.
Ive had my bike 5 yrs now 30000 mi and scrape almost at least once every time I ride. The right side floor board outter edge is mostly gone and I may replace the pan this summer but overall they go a lot longer than you would think.
IMO get used to it its part of owning a HD with floor boards!
In the "Ride Like a Pro" series Paladino says to learn where they scrape and get used to it. He scrapes them on all sharp low speed turns. Personally I get a little creeped out when I scrape on a faster turn; do that too far and you'll lever your tires off the street. I kind of like that idea of putting an acorn nut under there as a feeler.
Old Apr 28, 2009 | 10:23 PM
BlackRob's Avatar
BlackRob
I scrape mine just about every time I ride, even coming out of my driveway. I can see no damage to my floorboards and I have had my bike almost four years. Make sure they are not too tight to fold up and have fun scrubbing off those chicken strips.
Old Apr 28, 2009 | 10:57 PM
murd's Avatar
murd
No worries... be happy.
Old Apr 29, 2009 | 12:48 AM
TexFordD's Avatar
TexFordD
Adjust your back shocks to be a stiffer. They come out rated for 185 lb. driver and 150 pass.
Get the wrench from the Harley dealer and look at your manual. Adjust evenly.
Old Apr 29, 2009 | 05:15 AM
hpfatboy's Avatar
hpfatboy
Thats my biggest beef also, those DAMN floorboards scraping. No way i can lean into the corners the way id'e like to. Just part of owning a FATBOY i guess!
Old Apr 29, 2009 | 08:09 AM
fathanger's Avatar
fathanger
Stage II
Default scraping
mine's also lowerd im a scraping all the time, to make sparks come out sounds fun
Old Apr 29, 2009 | 08:52 AM
BigSeaDaddy's Avatar
BigSeaDaddy
I ride with two guys on night trains, one on a classic and a fatbob and they all get a kick out of riding behind me on my deluxe through the curves throwing up sparks. I did the bolt mod on mine and its easier to replace a bolt every now and then and not a floorboard.
Old Apr 29, 2009 | 09:08 AM
bmr's Avatar
bmr
Better than scraping your pipes.
Old Apr 29, 2009 | 09:46 AM
Mrawsome21's Avatar
Mrawsome21
I have an '06 Deluxe and I worried about scraping my boards since my Motorcycle Safety Instructor told me, "First time you scrape your boards it'll scare the sh*t out of you, after that it's nothing." And the first time I scraped 'em, it did. After that no problem.
Then one of my buddies told me, "Careful you don't catch those in a pothole while your draggin' 'em." Sh*t, after that I adjusted my riding style not to drag 'em.
Just my take on it.
Old Apr 29, 2009 | 05:50 PM
Reverend's Avatar
Reverend
Keep scrapin' & it's only a matter of time before you'll be off..
Where's your safety margin if you're grounding down? It only needs a bump or pothole & you'll be eatin' tar.
