Rocker C rear axle nut
I believe the rear axle nut on the Rocker takes a 3/4 inch hex bit, is this corrrect? Any ideas where i could locate a bit that size? I want to replace the nut with a topdownpro nut which will carry my sidemount plate.
Might just be worth going to the local bike shop and offering them 20 bux to remove the stock nut and replace with the new one.
Any tips, hints suggestions?
I looked at local used tool store and couldn't find any. Someone recommend on here
http://www.sjdiscounttools.com/vimhms26.html
This will allow you to remove your front wheel as well.
Cheap solution
I ordered the part online and was then walking through home depot, spied the coupling nuts (like the long nuts we have on our brake and throttle adjusts), grabbed a 3/4" one for 75c. Got home put one end in the axle nut and the other in a 3/4" socket and it came off in 2 secs...
All that effort and searching and it came down to dumb luck and 75c...
