68 tooth rear wheel pully
does anyone know what the part number is for a 68 tooth rear wheel pully for a international '06 softail springer?I have a 70 tooth on it know and i want to drop down 2 teeth,so i dont need to change the belt or crack the primary.Or where i can get a 68 tooth pully for a '06 springer softail?
i found they have a 65 tooth. you may be able to write to the company and ask the part number
http://www.nightrider.com/biketech/calc_gearratios.htm
with a smaller pully/spocket you lower the rpm, you can rev it higher get more rpm out of her "with the right cam" you will also go faster.You can have a small motor,spend less money and get the same performance or more depending what you do to her.It will keep up with the big motor boys.Plus it will be lighter then the big motors.Yeah off the line might suffer but in the long run its all ok
I know they make a 68 tooth for a dyna,and they make a 68 international for softails but no one can get a part number for the international 68 for the softail.I know i can get a 34 tooth for the front.I realy dont want to crack the primay.Plus going up 2 in the front is like going down 4 on the rear.
i think you should read this before you do something like that
http://www.nightrider.com/biketech/hdengines.htm
you could get a taller tire for less and then if you dont like it you can change back or get a 6 speed transmission
dustyshovel
04-04-2014 05:32 AM
