Rear Wheel Spacers
OK, I am about 160 miles from home, come out of a buddys house this morn to a rear flat tire, no big deal, got his lift, proceed to remove rear wheel to get tire replaced since about worn out anyway. No problem getting everything apart, now my ?, On the brake side there are 2 spacers, 1 about 1" long and 1 about 1/4" long, when we pulled out the rear axle the spacers fell out and now without my service book I do not know location for reassembly. Looks as the thinner 1 would go in swing arm then the capliper mount then the wider spacer against the bearing in wheel?? It is a 2008 Nighttrain, any help would be great. Thanks
Originally Posted by DECON BLUE
(Post 5699568)
On my '06 with the 200mm tire, the thinner spacer went between the wheel and the caliper. Before mounting the, wheel, set it up next to the bike and slip the caliper over the disc (as if it were mounted and see which one fits. The wrong spacer would make the brake pads rub, or not let the caliper mount at all..... |
1 Attachment(s)
according to the 2009 parts catalogue, the longer spacer (18) at the wheel and the shorter one (27) at the frame ... can't imagine they would change that from one model year to another.
Originally Posted by Rakthi
(Post 5699697)
© 2024 MH Sub I, LLC dba Internet Brands
