97 HD Heritage Softail....Starter Relay
Check out the link below. On the left side of the page that comes up, click ELECTRICAL - SWITCHES W/ CIRCUIT BREAKERS under frame. It shows the starter relay and diode and the assembly it is located on. It appears to be in the electrical box which I believe is under the seat area.
http://partsfinder.onlinemicrofiche....e=13&A=76&B=12
Don't know if your '86 is like my '94, but on mine, the relay is located under the seat, behind the battery, to the right of the ignition module, attached to the frame crossmember by a single screw. On mine, the relay and its connector is hidden under a rectangular black plastic cover.
Bullys FLSTN
08-19-2009 06:38 PM
