primary oil change 2007 fxstc
I know there are numerous threads but I can't find the answer. I just changed the oil in all 3 holes on a jack lift. This is my 1st time doing my own service. I did not close the derby cover and set the bike on the jiffy stand. and few ounces of oil spilled out. don't know how much. Is this a concern? What should the level be. can it be checked on the jiffy stand or only on a lift. I put in 1 quart as per the manual. how far below the opening should the oil be if it needs to be on the jack. Also I am in NJ and it is very cold. i rode the bike about 20 min to warm the fluid a bit. after I drained all the fluids i adjusted the clutch as per the manual but is says to do this at room temperture not on a hot bike. by the time I did this the air temp must have been 30 in my garage. Will this effect the adjustment?
Bart van der Meulen
Oil Archive (no new posts)
11
08-31-2017 08:22 AM
