Disassembling Forks (quick help if possible)
Old Feb 22, 2010 | 07:57 PM
neocontra's Avatar
neocontra
Yes it's metric, either 8mm or 10mm. it's on there tight and you need a long L shaped. Take the bent part of the allen key place it in a crescent wrench to act as a lever... that should do the trick. Keep a pan under there while you do it, oil will drip out.
Once the bolts are are out, you get the lower boots off by basically holding the leg and in a hammering motion pulling the lower off. The rubber seal will separate while you do that. Then they'll slide right off.
Old Feb 22, 2010 | 08:06 PM
snip0721's Avatar
snip0721
should be 6 mm. steve
Wakko47
May 19, 2012 07:53 PM
Wakko47
May 19, 2012 01:08 PM
Deuceandahalf
Sep 23, 2010 07:36 PM
Adam17
Oct 26, 2007 10:37 AM
smartbait
Aug 30, 2007 09:28 AM
