Calling all FatBoy Lo Owners
  #13521
Old 03-06-2017, 09:18 PM
Gommee's Avatar
Gommee
Gommee is offline
Devil's Advocate
Originally Posted by Freak Show
rode two weeks ago and now they calling for 3 inches on snow on sunday. kinda bummed. my stepson's friend lives with us when he's not at college, i'm taking him to the safety course this weekend. hope he at least gets one day to learn
Dan
Hope they supply a bike! Nobody touches the HOG!
  #13522
Old 03-07-2017, 07:04 AM
sbarron's Avatar
sbarron
sbarron is offline
Originally Posted by ILMFBL
Now wait just a minute there Gommee, I thought you were already over the edge.
^^^^THIS!^^^^
  #13523
Old 03-07-2017, 07:27 AM
joebad's Avatar
joebad
joebad is offline
Default Dash turn signal arrows flashing fast after CD front turn signal install
I believe this procedure, noted by Roadsterglide on another thread (New "Rushmore" Models under softail section of these forums), is what worked for me. I was asked to post how I solved the problem on my bike and I haven't had time to look for the Custom Dynamics instructions but I think this is the same. When I find those instructions later today I will post if there are any differences from what I've written below.
Roadsterglide indicates that in his case he needed to have his engine running while doing the following, but I don't know if I did, so you might try first with only the ignition on and if that doesn't work, fire her up.
1) Turn Ignition on
2) Turn on 4 way hazards by pressing the hazard button on the controls. DO NOT press both turn signal switch's at the same time. That is the way the hazard activate on PRE CANBUS bikes.
3) Turn the Ignition off letting hazards run. IF the bike has security they will flash 5 or 6 times and then pause. This is normal. They will go back to flashing normal hazard mode.
4) Let hazards run 1-2 minutes.
5)Turn Ignition back on
6) Turn off hazards
7) Turn Ignition off and then back on
8) Check function of turn signals
  #13524
Old 03-07-2017, 08:08 AM
Freak Show's Avatar
Freak Show
Freak Show is offline
Originally Posted by Gommee
Dan
Heya Scott, yeah you get to ride a 250 by suzuki or kawasaki. back when i took it they still had a yamaha 125
  #13525
Old 03-07-2017, 03:21 PM
Freak Show's Avatar
Freak Show
anyone ever see a picture of a fat boy with a head light cowl?. i'm going with lower bars soon, thinking of other ideas. i'm putting bars from a wide glide on
  #13526
Old 03-07-2017, 09:28 PM
Gommee's Avatar
Gommee
Gommee is offline
Devil's Advocate
Originally Posted by sbarron
^^^^THIS!^^^^
I resemble that comment...
  #13527
Old 03-07-2017, 09:33 PM
Gommee's Avatar
Gommee
Gommee is offline
Devil's Advocate
I had to re-do my license 12 years ago when I moved provinces. They neglected to add the motorcycle class when I got my new license.
The safety course I had to take had little Honda 100's. What a riot, it was more like stunt school!
  #13528
Old 03-12-2017, 07:22 PM
adam1948's Avatar
adam1948
adam1948 is offline
Default Wind deflectors #57400143
They work, installed them today and no more buffeting. Best hd hundred dollars i've spent, only thing is they are chrome, i might power coat or paint black? Any suggestions on real good spray paint?
skian (03-13-2017)
  #13529
Old 03-14-2017, 09:32 AM
sbarron's Avatar
sbarron
sbarron is offline
Most spray paints b rands follow similar recipes within the chemical makeups of the paints. Either an epoxy or an acrylic would work, I'd stay away from a raw lacquer finish. The main thing is the prep. If you are painting over chrome, make sure you clean, scuff, clean again, and prime/paint while surface is warm and clean. I'm not sure I said clean enough. After priming, give the paint a thin coat and let dry for a few minutes before applying a second heavier coat. The light coat will help the next coat adhere. If the correct steps are taken, some amazing results can be had with rattle cans. Remember, in many cases, it's the same product being sprayed by a body shop, just applied differently.
adam1948 (03-14-2017)
  #13530
Old 03-17-2017, 08:20 AM
Mustang Matt's Avatar
Mustang Matt
Mustang Matt is offline
2nd Gear
Originally Posted by jdmorg13
In denim. Just put on the forward controls. I've got the FL foward controls from HD and Arlen Ness extensions. Definitely makes a world of difference. Any tall guys out there (I'm 6'3" with a 35" inseam) that feel cramped on the Lo, this is the way to go. My legs can pretty much stretch straight out. Next up are some 4" risers and then I'll be done for awhile.
Hi jdmorg13, I'm 6'5" tall with a 36" inseam, so was wondering how the forwards felt and do you have any pics of you on the bike so I can see how it looks, as I'm thinking of doing the same thing to my FB Lo to go with my 18" apes?
Quick Reply: Calling all FatBoy Lo Owners
