Calling all FatBoy Lo Owners
got the lights put on but when i got home i noticed one of the bulbs in the head light isn't on and when i turn on the high beam nothing changes. Since i'm not used to this type of headlight, i'm guessing it's in high beam and the low is out. When i get a chance next weekend i'll take it back so my buddy can look at it. hoping it's something simple. or it could be a bad light.
so i changed the light back to original one. it was fine for a while but just got back from a ride and when i got in the garage i turned on the high beam and got i got nothing. It's got to be the wiring.. any ideas?
I would start by removing the jumper harness for the passing lights. the one you bought to keep the passing lights on with the high beams. Check to see if high/low works correctly without it. If I remember there are a couple of connectors on it that are similar, may be hooked up wrong. I'll try to get you some pics tomorrow
Yes and holy chriminey. I was on it since DaveFLSTFB started it, day one. I don't post much. Now and then, I check back to see if there's any new ground being covered. It's funny to see a lot of new people come and go, and then there's a few originals, like Sgt Jim, that remain consistent.
Super cool. I still have my Lo. I toss around the idea of something else, but then I think... "why would I?".
When the light is cooled down, at first start the high comes on. then i'm guessing after heating up it turns off.. The led i just bought comes on for a few seconds then turns off right away. My original head light i have an LED bulb in it and it stays on for a bit, then turns off later.. but yeah shoot me some pictures, it's getting confusing. Thanks Chuck.
the headlight has another modual inside of it now that has to be plugged into, i'm guessing because of the addition of the other lights. because when i tried to plug my original light back in without it, it wouldn't work.
i took it to a shop and they did all the work. the owner is a friend of mine, so i sent him a text and they told me to bring it back as soon as i can.. and like i said, it's only the high beam that goes out
