Sokustom Bag Attachment
At first I kept an eye on it thinking zip ties would break, etc., but evertyhing is and has been worry free.
I'm also not terribly worried about rubbing some paint on the swingarm. IF I ever decide to take off the solo bag AND not replace it with another one, I guess I'll have to live with touching up the swingarm.
Either way, I love having a bag there and stick my lunch in it for work, or misc stuff for day trips.
If it's a detail you dont like, then by all means you could run straps or bracket, or whatever. I've had many compliments on my bags, but no one has ever wedged their head behind there and said "man! those zip ties look like azz!" Lol
Enjoy and let us know what you come up with.
Do you have any more closer shots? That looks nice , but hard to see whats going on.
I basically did what others did. I used 1" coupler nuts for the forward/top and lower chain guard mounts. The rearmost chainguard mount, I used a 3/4 " spacer and a 1.5 inch bolt. This all allows the bag to sit approx 1/8th inch off the swingarm. Inside the bag is where I used plexiglass.
All hardware is 5/16 and in assembly order. (I painted all visible hardware black)
8x11 plexiglass sheet cut to fit inside bag.
Lower mount
3/4" set screw or stud (threads into chain guard/frame)
two spacer washers
1" coupler nut
Fender washer (against the bag outside)
3/4" button head bolt and a washer (inside bag)
Front mount upper
1" bolt (replaces original shorter bolt, reuse existing washer)
two spacer washers (other side of chain guard)
1" coupler nut
Rear mount upper
Begin inside bag
1.5" bolt and a washer
Fender (or smaller) washer against the bag outside)
3/4" spacer
Thread into existing hardware in chain guard.
