HELP... right turn signal will not shut off
06 heritage softail, riding along last week look down, right turn signal is blinking, push button to cancel, nothing... keep pushing... nothing... push both left and right... flashers come on, push both again both shut off.... 10 minutes later... right signal is back on for no reason... won't shut off this time regardless.... shut bike off at bar, come back out couple hours later, turn bike on and F'n right signal is blinking and won't stop. I resorted to pulling both bulbs out inorder to ride but that doesn't stop the idiot light on the dash plus it triggers the red key shaped idiot light to stay on.
What the L is going on? I've been riding half dozen times since and the light is still blinking. Any suggestions before I have to surrender to being raped at the dealer? Thanks much, ya'll have a good one. N8
Haven't changed anything on the housing (at least not in past 2 years).
I haven't taken the housing apart yet, but will to check the switch. Any suggestions on how to check the switch to see if it's stuck "on". I ain't the best with electronics but know just enough to be dangerous.
Thanks for the replies, more suggestions/help is welcome until I find out what is going on.
i had a problem with mine on the r side. it was stuck on like in the flash position but was constantly on. rode one day put the bike up went back thru the garage couple days later the bulb had melted the plastic cover...even with the ingintion turned off the light was on. i've changed a lot of stuff, but like u nothing recently. i finally pulled the wheel n removed the tssm and unplugged connector 28b (i think from under the dash) the connector under the dash that sends power to the dash indicator light. this was after pulling all the fuses, checking all my wiring, etc...anyway long story this finally got the light 2 go off. i cleaned the connector w alcohol n been good since. shoot me a pm if this is as confusing as i think it sounds.
not exactly details....but best i could do b4 work...also i couldn't send ya a pm. so check ur visitor messages. hollar if u need any more help. it's really not that complicated, just takes time. rtr
I have the same issue, only its the left side. I would push the right one twice and it would cancel out the signal. Start the bike back up, and the dang light was back on. It has stopped doing that, now when I push the left signal, the idiot light on the dash comes on, but the bulbs dont blink. I am thinking I have a bad switch, only thing is, if it is bad wouldnt the light on the dash not come on as well? Sorry for the highjack, I will be following this thread.
