Harley Davidson Forums
Harley Davidson Forums (https://www.hdforums.com/forum/)
-   Softail Models (https://www.hdforums.com/forum/softail-models-7/)
-   -   Security kit doesn't work anymore. (https://www.hdforums.com/forum/softail-models/545269-security-kit-doesnt-work-anymore.html)
Lucky22 Jul 31, 2010 02:11 PM
I can't activate mine Security kit anymore. I all ready replaced the battery of the keyfob. Do you know what the problem can be.
DR. V-TWIN Jul 31, 2010 02:26 PM
Could be the TSSM (turn signal security module). Check your fuses first. And are you sure the new battery is good and seated properly in the fob?
Drew
tlb Jul 31, 2010 02:36 PM
did you reprogram the fob after you replaced the battery?
Lucky22 Jul 31, 2010 02:45 PM
I didn't reprogram the fob. The battery is correct. I wil check the fuse tomorrow. Time difference. I live in the Netherlands. Home of hookers and drugs LOL.
snook592 Jul 31, 2010 05:06 PM
Well there's your problem you need to stick your finger in it ....LOL :icon_dance-tap:
oct1949 Jul 31, 2010 05:34 PM
din't do anything to mine cept put in the new battery....
din't know U had to repro...
course it wasn't dead prior...
tlb Jul 31, 2010 06:52 PM
I not reprogram mine either, but it would be the next logical step. It takes about 3 minutes to program. I would also take the fob into an auto parts store that has one of those displays that checks your fobs battery, to see if it is working or not.
If you eliminate the fob as the problem, then you check the fuses and eliminate them, only connectors and TSSM left.
If everything was good before he replaced the battery, then I would think it is the fob.
I would go to the point of getting a buddies spare fob that works and reprogram it to make sure the my fob is good before I replaced the TSSM. Fobs are cheap on ebay TSSMs are not.
Kowan Jul 31, 2010 07:39 PM
Mine are two years old and I just replaced the batteries in both. Both work just as they did prior to only changing the batteries.
Other Sheep Jul 31, 2010 09:14 PM
You put the new battery in upside down.
04reddeuce Aug 1, 2010 12:51 AM
Yep double check the battery. Happened to me.
© 2026 MH Sub I, LLC dba Internet Brands
