Deluxe owners with 21's on front a little help PLEASE
If the hub and spacers are the same size and the brakes pads are letting the wheel spin freely, then IMO it is the fender that might be off center. When I switched from the fatter original deluxe 16's to the 21" rims I had a similar problem which I solved by loosening the fender bolts, centering the fender (it took a bit of gentle bending) then tightening the bolts up one side at a time. That solved the problem. A skinnier wheel you will notice much more of a misalignment than a fatter wheel under an FL fender.
Well just got out of the garage and switching around the spacer did nothing at all I still have the same problem it is off center .This time I hooked the caliper back up and it lined up with the rotor and spins freely but it still is off center.I really dont know WTF is going on.Even if I get a smaller spacer for the caliper side There is no way the rotor will line up with the caliper.The rotor will be too close to the fork and I dont beleive it could even be shimmed.I think it could be shimmed out ward but inward seems impossible given the mounting location for the caliper on the fork.I just finger tightened everything if I torque everything to proper specs would that do anything ??? Ive talked with two people that have done this without a problem.Wish I knew how to post pics Would that help anyone with a solution.There is NO WAY I am bending my fender that seems like a poor solution to my problem IMO.Plus that white ice pearl and black ice pearl paint is just too pretty.Surprised I have not scratched it yet messing with thing.
my buddy had to bend his fender back somehow it got bent between wheel changes. wasnt that difficult to kinda knock back into place. if your wheel lines up with the forks on both sides and doesnt line up with your fender its your fender. check your spacers what are they like a 25 mm
If your brakes don't bind with wheel installed, your spacers are correct. I would not try to bend the big ol front fender either. All I can think is that maybe the dish is out on the 21 you're using. This would cause the rim to be pulled off center of the hub. I have no idea what the specs are but that would be next guess. You can lay a straightedge across one side of the rim at the bead and measure how far it is to the hub. Then check this against another 21" rim. Hell, I can measure mine tonight for you if it helps.
![Icon Nut](https://www.hdforums.com/forum/images/smilies/icon_nut.gif)
