Searched and Searched.......Fender Chop
After you scribe the line of the final shape, make your cut just outside the line. Then take the rest of the metal off with some sort of sander. Smoothing and shaping down to the scribed line. As long as the first cut doesn't cross the scribed line. You're good to go, as you still have metal to work with.
Ceez (06-26-2017)
Here's how i did mine: 1. Mount fender and put masking tape over the area that you plan to cut. 2. Mark your lines onto the masking tape to make sure you like the look of the line. 3. Pull the fender off and get a dremel with a few metal cutting blades ready to go. 4. I used a paint can lid to mark my lines and give me the round edge on the sides of the fender. 5. Clamp the fender to your workbench and start cutting with the tape still on (this will help keep the paint from chipping). 6. Once you have the cuts done use a dremel grinding bit to work in the angle and smooth all the edges. If your carefull enough you should be able to get some touch up paint to do the fresh edges and shouldnt need to repaint the fender.
Couple things to keep in mind are the license plate needs relocated and brake lights need to be figured out. I ended up running the side mount plate and a converter that makes my rear turn signals the run/turn/brake signals. Let me know if you have any problems
