Back rest adjustment...
Old Oct 26, 2010 | 07:27 AM
SportsterPapa's Avatar
SportsterPapa
Question Back rest adjustment...
Don't want to screw up anything.
Wife has a bad back, needs the pass. back rest to be a bit higher up.
Have the standard low upright, medallion style with the nice wide pad on it.
The pad would be fine if I could just slide it up higher on the upright about 2 or 3 inches or so, doable?
I took a quick look at what i thought was securing the pad to the upright: the cross bar with the two Phillips head screws; but when I loosened them the pad was still secured to the upright. Is there another screw behind the round "Harley" insert in the medallion portion of the upright? if so how do I access it?
Is there an obvious reason not to move the pad up a bit on the upright?
Buying the "Tall" upright is an option, but the pad that fits that isn't as nice as the one I have now and the "Tall" upright is 20" which is really a lot more than I need to add...
Thoughts. (some photos of the bike are up in my album, though the one showing the backrest ain't the greatest...)
Old Oct 26, 2010 | 06:49 PM
user 6974208923's Avatar
user 6974208923
From what I can see from my own passenger backrest ('08 Heritage softail) and from what I was told by a HD parts guy there is a screw hidden behind that medallion. You would have to remove the medallion to gain access to that third screw.
I was told that there is double stick tape holding it on so a good sharp single edge razor blade and steady hands should do it. From that point on I can't help ya.
Old Oct 27, 2010 | 05:31 AM
SportsterPapa
Thanks for taking the time to respond. You are correct, it was two sided tape & a screw behind the medallion.
That said I found that I had the "medium low" upright on the bike & the "low" was only a couple of inches longer. The wife can't help the bad back & needs full support, so I thought I'd order the tall... Found out the "Tall" upright (like 20") won't fit the '09 FLSTF. I was stuck for a while as to what to do until i came across an Ebay auction for what appeared to be a Harley sissy bar/upright that was 11 1/16 wide at the base & 20" long (stated in the auction that it fit all the newer Fatboy's (with the 200 rear tire & wider fender). Turns out it is an aftermarket made by V-twin manufacturing co. Good source for Harley fitment and an even lower price. Got one shipping from NY, chrome upright, long pad and hardware to attach pad shipped via USPS Priority mail to FL. all for $125. Between what Harley parts & tax would have come to I saved $50... Now have a "Medium Low" upright with attached backrest for sale on Craigslist
Black Bettie
Aug 26, 2013 03:09 PM
svt_ct
Mar 27, 2013 03:21 PM
SportsterPapa
Softail Parts
Nov 10, 2010 11:33 AM
plutnicki
Softail Parts
Jun 17, 2010 01:58 PM
bdjhog
Jan 3, 2007 02:09 AM
